Wrenchbender Ret.:
I see you live in Lenexa, KS. Did you do the rearend ring & pinion changeout? I have purchased a master setup kit, including 3.08 ring & pinion and Eaton posi unit that I plan to have installed in my '66, C-10 that has a factory 327cid/SM420 granny-low 4-speed and factory 3.73 posi. Any suggestions on a dependable, local mechanic that has the tools and know-how to do the swap? Thanks in advance for your input.
