| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Most of the canister filters have a beehive-shaped spring that holds the filter element down against the bottom so oil doesn't bypass the cartridge . There is a small metering hole in the center standpipe about 1/16" in diameter that controls the flow rate and prevents oil pressure loss to the engine. Jerry
