| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | I just bought two engines that I also need help to id. first is casting #3837004 with A16 6 behind the starter and the second is #3836233 but the starter is still on it so can't read the numbers. What is the max bore for these engines? One is already .060 over. Thank you in advance, Gerry Lee | | |
