Try going to a slightly larger diameter oil pressure line and a flared fitting, not a compression type. I like to use 3/16" copper tubing and flare adapters at both ends of the line, not the usual 1/8" tubing and compression fittings. The diameter of the tubing doesn't change the pressure reading, and if anything, the bigger line might make the gauge respond to pressure changes more quickly.
