Where does it say a booster and master cylinder has to be mounted in factory location? This unit in my 37 Buick is moved back 19" with a longer push rod from pedal to booster. We did a 30 Plymouth with an IRS that the brake unit was BEHIND then rear axle. Had a bell crank at front that reversed push to pull and a second at the rear that converted back. We did a 40 Ford coupe that had the booster/mc in the TRUNK. Do a search on "remote mount p/b". All the clearance needed for a remote mount unit is for a 1/4" brake line.
