I have a new old stock AC 4149 for comparison. My guess is they used the wrong rocker arm in that problem pump. Look the gap at the bottom (pivot). There is a lot of the pin showing.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
