So the order of installation is install the Bakelite or nylon spacer, then the spring, stem and cup. The photo I posted of the parts, the smaller spacer is an original Bakelite part. The one to the right is a Delrin piece. A friend cut a few down for me from a piece of higher temp Deleon rod I picked up on eBay. Also, you want the spacer to be a bit smaller so the grease can get around the spacer and lube the shaft.
Mike
