| | | Forums66 Topics128,049 Posts1,055,651 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Block casting date is Feb. 02 1962. Cool! The stock head was a 3836850 and more than likely it developed a crack. Back in the day it was a lot cheaper to find a replacement from a junkyard rather than repair the original. I think the consensus is that the extra cooling holes are only necessary when you want your truck to do heavy duty hauling. The engine has the early version PCV system. I would ask for the original oil bath air cleaner since it is has the connection to the valve cover.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
