This is a picture sent to me from the VCCA web forum member Larry Elgeaton. In response to a discussion I had about it with Mike Russell. You should check out the forums over there…. Nice folks.
The brace is fastened to the fender using a tab that is positioned on the inner edge of the outside edge of the fender.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
