3 members (baldeagle, Shade Baby, 1 invisible),
94
Mod | | | Forums66 Topics128,125 Posts1,056,336 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | little fmcsa handbooks give the specs for bleed down time etc, you can pick them up at most truckstops. Jar may be for collection of moisture not shore haven't run across it. seems like trucks of the 70's had a place to introduce alchol into air system but I don't remmember now how it went. nowadays with airdryers and proper and regler bleed off not much of a problem. Sometimes pour airline antifreeze in trailer gladhands if there's a problem. suggest you install pull type bleeders on air tanks so you can drain moisture from tanks regularly pain in butt laying underneath truck in freezing weather with a flare trying to thaw frozen valves | | |
