| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy qside, you can do the job without removing the engine, you can support and raise the engine slightly from underneath with a hydraulic jack, make sure you use a piece of wood to spread the load over the surface of the oil pan. If you remove the brackets from the engine rather than lifting the engine high enough to clear everything it will be safer. There is one cushion under the crossmember as well. Good luck with your project and be safe. | | |
