| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | If you choose to remove the valve lifters from their bores for cleaning, be sure to replace them in the same holes they came from. Each lifter and the camshaft lobe it runs against have a unique wear pattern that does not need to be disturbed. Jerry
