| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Just guessing- - - - -you've probably got a trans from the late 1920's or early 30's. In the mid-1930's GM launched an advertising campaign for the "silent second gear"- - - -a transmission with constant-mesh helical gears and synchronizers to do the actual shifting rather than sliding straight cut gears in and out of mesh. People were so used to the noisy straight cut 1st. and 2nd. gears that they would drive for miles in second- - - -forgetting to shift to high gear which was direct drive. Jerry
