| | | Forums66 Topics128,049 Posts1,055,684 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,189 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,189 | Kevin is right. I use a small bolt and nut to hold them on. Occasionally you need need to use a sheet metal screw if you can't get behind the mounting surface to hold a nut on.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
