10 members (Bruce 1954-4100, frogfarmer, DennisM, Joe H, Joe Lowe III, Shade Baby, 3B, Oswald, Cosmo, 1 invisible),
73
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Farmer Paul, You should read this. It's a carefully researched PCV upgrade solution specifically for this engine. It's complete with theory of operation, measurements of vacuum pressure, photos, and instructions how to do it yourself, or you can purchase a complete conversion kit with pre-bent steel vacuum line, the correct pcv valve for this engine, grommets, etc. By the way, the recommended port is exactly where you installed - the wiper port on the intake manifold. Instructions to make it yourself and theory of operation: http://devestechnet.com/Home/PCVInstallCustom Made Kit: http://devestechnet.com/Services/PCVUpgrade
1950 Chevrolet 3100 (Ol' Roy)
