Did you check your bushings? The flap should fall open on its own without the spring. From your pictures, it looks like the spring is moving around the shaft rather than the shaft being moved by the spring.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
"Frank" gets a new lease on life
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The Saga in the DITY Gallery ~ and the story continues
