| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | You can also use JB Weld's "Quik-Weld" in the same way if you are on a budget. It sets up faster and sands smooth also. Hold vertical patch pieces in place with common masking tape until the JB Weld is cured. I used the regular JB Weld to repair the seam between the roof and pillar on my 1952 40 years ago and still have no problems.
