| | | Forums66 Topics128,085 Posts1,055,969 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 | Mike - like you described, I drilled 1/8" holes in the center of the track about 3" apart and plug welded it to the inner cowl panel. I then ground the weld so as to not interfere with the rubber installation. It worked out well for me. Just make sure to use a low heat setting on your welder so you don't blow through the track. They are not very thick. Good luck!!
Charlie
'51 3100 5-Window (Restomod in progress)
