7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Your saying 318 inline just to be sure is that a gas motor? I don't think they were putting the diesels in that early If it were diesel the parts are still available. 6-71's were produced from the 40's thru 80's at least. With 53 series coming in a little later. The reason I was asking was the 6-71 most common was the 238 whereas the 8V-71 base was the 318. They were set to run about 2100rpm but a lot of folks set the govenor 2600 or better, run fine plenty of oil leaks. Spanky proably has better dates on the engines and when they went into COE trucks. | | |
