| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Just measured a stock pump for a ‘59 235, which should match yours. They are as follows: - From the casing to the shaft end: 2-9/32"
- From the pump casing to the fave of the fan hub: 1-31/32”
- From the end of shaft to the fan hub face (where the fan sits): 1/4"
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | |
Entire Thread
Water pump, overheating questions
| showme | 09/13/2021 4:58 PM |
Re: Water pump, overheating questions
| 2ManyTrucks | 09/13/2021 5:30 PM |
| showme | 09/13/2021 6:54 PM |
| 2ManyTrucks | 09/13/2021 7:15 PM |
| showme | 09/13/2021 8:43 PM |
| Justhorsenround | 09/13/2021 9:41 PM |
| showme | 09/13/2021 10:07 PM |
| showme | 09/13/2021 9:43 PM |
| Hotrod Lincoln | 09/13/2021 11:36 PM |
Looking for someone to rebuild a water pump
| showme | 09/14/2021 1:22 AM |
Re: Looking for someone to rebuild a water pump
| Phak1 | 09/14/2021 12:50 PM |
| dgrinnan | 09/14/2021 1:17 PM |
| showme | 09/14/2021 1:55 PM |
| Phak1 | 09/14/2021 2:08 PM |
| showme | 09/14/2021 2:27 PM |
| showme | 09/14/2021 1:53 AM |
| Hotrod Lincoln | 09/14/2021 2:17 AM |
| showme | 09/14/2021 2:38 AM |
| Hotrod Lincoln | 09/14/2021 2:57 AM |
| Phak1 | 09/14/2021 1:17 PM |
| Justhorsenround | 09/14/2021 2:58 PM |
| Phak1 | 09/14/2021 5:23 PM |
| Pre '68 Dave | 09/14/2021 6:02 PM |
| showme | 09/14/2021 6:17 PM |
| tclederman | 09/14/2021 7:00 PM |
| Phak1 | 09/14/2021 8:46 PM |
| showme | 09/19/2021 10:15 PM |
| Hotrod Lincoln | 09/20/2021 12:36 AM | |
