| | | Forums66 Topics128,098 Posts1,056,166 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Sounds like you ran into a similar problem that I have You have a small airlock under the thermostat which doesn’t let it warm up as nice Eventually it will get hot and open But it’s much nicer for everything if you drill a small bypass hole through the new thermostat before installing Then all these issues go away -s | | | |
Entire Thread
Water pump, overheating questions
| showme | 09/13/2021 4:58 PM |
Re: Water pump, overheating questions
| 2ManyTrucks | 09/13/2021 5:30 PM |
| showme | 09/13/2021 6:54 PM |
| 2ManyTrucks | 09/13/2021 7:15 PM |
| showme | 09/13/2021 8:43 PM |
| Justhorsenround | 09/13/2021 9:41 PM |
| showme | 09/13/2021 10:07 PM |
| showme | 09/13/2021 9:43 PM |
| Hotrod Lincoln | 09/13/2021 11:36 PM |
Looking for someone to rebuild a water pump
| showme | 09/14/2021 1:22 AM |
Re: Looking for someone to rebuild a water pump
| Phak1 | 09/14/2021 12:50 PM |
| dgrinnan | 09/14/2021 1:17 PM |
| showme | 09/14/2021 1:55 PM |
| Phak1 | 09/14/2021 2:08 PM |
| showme | 09/14/2021 2:27 PM |
| showme | 09/14/2021 1:53 AM |
| Hotrod Lincoln | 09/14/2021 2:17 AM |
| showme | 09/14/2021 2:38 AM |
| Hotrod Lincoln | 09/14/2021 2:57 AM |
| Phak1 | 09/14/2021 1:17 PM |
| Justhorsenround | 09/14/2021 2:58 PM |
| Phak1 | 09/14/2021 5:23 PM |
| Pre '68 Dave | 09/14/2021 6:02 PM |
| showme | 09/14/2021 6:17 PM |
| tclederman | 09/14/2021 7:00 PM |
| Phak1 | 09/14/2021 8:46 PM |
| showme | 09/19/2021 10:15 PM |
| Hotrod Lincoln | 09/20/2021 12:36 AM | |
