9 members (farmallb, IHPWR, JW51, baldeagle, Dennys28, Bill Hanlon, Peggy M, Maybellene, Southerntruck),
69
3
Mod | | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Valve timing and adjustment, initial carburetor settings, and ignition timing can all be done without cranking the engine. It's not necessary to turn the ignition switch on to check compression. A simple toggle switch upstream of the ballast resistor can be used to interrupt voltage to the coil, and a short pry bar between the firewall and the start pedal linkage puts all the starting controls in one place under the hood. Backing the fuel pump attaching bolts out a couple of turns and moving the pump housing up and down by hand will verify that it's working properly, and also fill the carburetor float bowl without cranking the engine. Maybe making a living doing all this stuff for 60+ years makes me "Captain Obvious"- - - -or maybe it's just plain old common sense! Jerry
