| | | Forums66 Topics128,130 Posts1,056,712 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I would check the linkage first. It may be so sloppy that it doesn't go into gear all the way. The shift forks in the shift cover wear and they jump out of gear but I don't think it would get progressively worse that quick. Have you checked the oil in the transmission? If it isn't the linkage, there is a good chance you are ready for a transmission rebuild. | | |
