| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | Pulled fuel pump and observed some scratches in the raised lips that sandwich the diaphragm between the two halves of the pump. I put a piece of sandpaper on the bench and used a twisting motion to resurface the two halves. Reinstalled pump and problem solved. I think one or more of those scratches might have been enough to let just a little gas through and then spit out that hole. Oil seems to be ok but I'm going to change it anyway. Oil is cheap- engines are expensive. | | |
