6 members (Wayne67vert, Gray_Ghost, klhansen, Joe H, baldeagle, Simon1954), 100 guests, and 12 robots.
Topics128,019
Posts1,055,343
Members48,419
#1421464 08/21/2021 11:51 PM
' Offline
OK, so you guys helped me get the generator cut-off problem resolved now on to the fuel pump.
Engine running good but fuel pump is spitting gas through the little hole you can see just to the
right of that hump on the left side of the picture. I rebuilt the fuel pump but must have done something wrong.
As I sit here looking at the location of that hole I'm wondering if gas is getting into the oil. I'll check
that tomorrow but for now why is it spitting gas through that hole?
'37 barn find #1421469 08/22/2021 12:24 AM
That behavior usually means a hole in the fuel pump diaphragm. And yes, if gas is exiting there, it is more than likely getting into the crankcase, too.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
'37 barn find #1421475 08/22/2021 1:19 AM
Pull the dipstick and look at the oil on it. If it's over full, and/or thin and watery and smells like gas, there's your answer. The spit hole is there to vent any gas that gets to the underside of the diaphragm, but it seldom handles all of a bad leak.
'37 barn find #1421481 08/22/2021 1:53 AM
' Offline
Well then, off comes the fuel pump.
'37 barn find #1421810 08/25/2021 2:32 AM
' Offline
Pulled fuel pump and observed some scratches in the raised lips that sandwich the diaphragm between the two halves of the pump. I put a piece of sandpaper on the
bench and used a twisting motion to resurface the two halves. Reinstalled pump and problem solved. I think one or more of those scratches might have been enough
to let just a little gas through and then spit out that hole. Oil seems to be ok but I'm going to change it anyway. Oil is cheap- engines are expensive.
