| | | Forums66 Topics128,163 Posts1,057,072 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | I use 2 hose clamps with a short piece of flat aluminum between them to keep that rear collar tight. One clamp on the collar, the other on the shaft. The flat aluminum piece clamped between them keeps the collar from rotating. I believe Phak1 is correct about the cork packing wearing in. My collar continued loosing after a couple of tightens so I went to the clamp method and no more leaks from that rear seal. Me too
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
