| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | Hello all working on 1954 chevy 3100 12 volt . working on the AMP gauge gauge shows slight discharge . But tester says 13.9 volts at battery is it possible I have the 2 wires switched on the back of amp gauge showing slight discharge instead of slight charge . Dose it work that way THANK YOU SO MUCH!!!!!!! | | |
