3 members (78buckshot, Ridgeback, 1 invisible), 109 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1421241 08/20/2021 1:50 PM
PA OUTLAW
PA OUTLAW
Hello all working on 1954 chevy 3100 12 volt . working on the AMP gauge gauge shows slight discharge . But tester says 13.9 volts at battery is it possible I have the 2 wires switched on the back of amp gauge showing slight discharge instead of slight charge . Dose it work that way THANK YOU SO MUCH!!!!!!!
jrhackett #1421242 08/20/2021 1:58 PM
Moderator, Electrical Bay
That is possible. Disconnect the battery and switch the wires at the ammeter and it should read correctly. AC current doesn't care about polarity on an ammeter, but DC current does.
~ Jon
