7 members (FishinToms53, Hotrod Lincoln, Rich'sToys, Stovebolt48, 50shep, Millenimech, mason86),
75
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 56 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 56 | thank you every one . i dont have the sock it just a hole in bottom for fuel line. carb king i took your advice. and fuel pump worked but in truck it did as well for a few days then stoped. so all lines are clear. i bought same pump that i took out . so just went to check box . in made in china. i was hoping it would be usa. so just in case it a faulty pump. ill get another one from classic trucks and ask to make sure its usa made. im not a fan for supporting china. cam lobe feels good and truck runs finewhen it get gas.im at a lots. right now filter is full of fuel.but im worried to drive it sense it can die today or two days form now .if float stuck up would that prevent fuel filter from filling up. just a thuoght . | | |
