Bart, I don't understand. I mentioned the Runtz only in response to your post immediately above mine. You said they work, I said I tried one and it failed. Initially I did want a converted gauge because I didn't see a suitable alternative to the Runtz type resistor. I then thought about the buck converter I used on my heater and how one would probably work on the gas gauge so I mentioned that. Further consideration led me to think that using a buck would allow future restoration to stock if my son desires. How is that upsetting?
