Originally Posted by Barnfind49
Is there a good ground going to the sending unit? I believe one screw has a brass contact under it for a ground ring termial.
Yes, I have verified that there's a good ground to the tank. I also jumped from the sending unit to the negative post on the battery. Neither corrected the condition.
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
