The distributor that was used with the polarity reversing switch used a set of points that was insulated from the housing. If the reversing switch is not used, it's necessary to ground the non-moving point to the housing to complete the primary ignition circuit when the points close. That switch was only used for a short time, without a sufficient increase in the life of the points to justify the complexity of the circuit.
