| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Greetings. I’m rebuilding my 1957 1/2 ton manual steering box. There’s a couple of things I’m not sure about, and I haven’t found anything in the search area.
The worm bearing adjuster looks as though the bearing race should be replaced, but I can’t tell if it requires replacing the whole adjuster. Is the race machined into the adjuster?
I have two bushing in the kit. I need a shorter bushing for the side cover that fits the sector shaft. It looks like the right diameter, but it’s too long. Can I cut it down to length? | | |
