I thought the 3/4 ton longer bed had 3 stake pocket supports ILO 2 that the regular 1/2 ton had...??
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
