0 members (),
132
3
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would start with changing the spring in the latch mechanism. The spring that is an exact match is the 1939-1946 door handle "Anti Droop Spring" part number DP146R from Jim carter. Anti Droop springIf you should experience what leo describes above, here is a link to what i did to solve the problem. https://www.stovebolt.com/ubbthread...e-rear-barn-door-handle.html#Post1276309Thanks, Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
