Did you bench bleed the MC?
Are you following the shop manual on how to bleed the brake system? Do you get fluid out of the wheel cylinder bleeders when bleeding the system?
Do you still have the Hydrovac Booster in place?
Have you adjusted the brake shoes?
Mike B
