Greg - got the pictures, thank you!
The three single barrel Carter YF side-draft carbs work VERY well on the 235. We have done several sets, and owned a few sets (now sold out).
There are issues: (1) the die-cast choke cable retaining casting breaks if abused, and (2) the fuel valves in the popular aftermarket rebuilding kits are WRONG, as are the bowl cover gaskets.
Additionally, there are 4 separate and distinct generations of the Carter YF, and MOST parts do not interchange among generations (although "rebuilders" try to do so). The Corvette YH's are generation one. The later turbo Corvair carbs are from generations three and four.
Jon.
