| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | The tank I got came with a sheet of self-adhesive 1/16" thick neoprene which you could cut as needed (according to the instruction sheet that came in the box). Very impressive product and less costly than many of the other options out there. If your outside rubber grommet doesn't seal quite right, use some 3M 08509 Auto Bedding and Glazing Compound. It stays flexible until a week after forever.
