2 members (Hotrod Lincoln, 1 invisible),
137
2
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I used a long narrow tank from a maybe late 80s chevy pickup. Mounted it on the passenger side frame rail just behind the battery. difficult part is fabing up the filler. I'd just take your measurements and head to pick n pull. I've since gone back to the stock tank under the seat, but you can make other tanks work. | | |
