| | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Doc, the ones with shims usually bolt to the block, not the bellhousing. Since the pinion gear on that type of starter is slightly below the center line of the flywheel, shimming it further down keeps the teeth from bottoming out in the flywheel gear. The bellhousing-mounted ones generally don't give any problems. A sneaky trick to check tooth engagement is to paint a dozen teeth or so of the flywheel gear with a rattle can and spin the starter with the ignition disabled to see how much paint gets rubbed off. About a 90% tooth engagement with a bit of paint still showing at the bottom is ideal. Jerry
