| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | One advantage to using rigid tubing is that it won't be compromised by exhaust heat. Both those lines run pretty close to the exhaust pipe, and just a minor mistake in routing them can result in a heat-damaged line that can empty the engine of oil in just a couple of minutes. Some installations I've seen use 1/8" pipe nipples 6" long into the block ports to avoid getting the flex lines too close to the exhaust. Jerry
