| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Get the screw head red hot with an acetylene torch. It will back out with nothing more than a big screwdriver. Be sure the screwdriver bit fits the entire slot, thickness and width, even if you have to grind it to fit. Jerry
