Hy KevinW, the original rear of engine crossmember was very important to the strength of the overall chassis, but seeing as how the front suspension has been changed and the engine and its mountings will be changed, I don't see a problem with removing the remnants. I would like to see a substantial transmission support crossmember installed to tie the frame rails together when all is assembled. Good luck with your project.
