Keep in mind the original rear axle location is not centered in the rear fender for some unknown reason. It was approximately 1-1/4" forward of the fender centerline on my '51-3100. It was not a problem as I was replacing the original rear axle and leaf spring set up for an open axle, four-link, and coilovers. I recommend you install the bed and drop a plumb bob down to the axle to be safe. Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
