Winter is Coming
I'm about to put a ZZ3 345hp crate motor in a 1950 3100. It's not going to be drag raced. My question is will the stock rear leaf springs work ok? Will be using a Camaro 10 bolt rear end. Any thoughts or comments? Thanks -Noman51
