Find a set of matched Carter W-O carbs for a CJ-2 Jeep, the flathead 4 cylinder used in WW II. There are usually several of them available on Ebay. Stay FAR away from the new offshore-made substitutes that are advertised as replacements. Rebuild them to be as close to identical as you can. They will only be slightly overcarbureted on a 235, not massively too much.
