look at where the temperature bulb is located. My 292 goes into the head right beside an exhaust port. It runs 210 all day, goes up to 225 on long hills. But the coolant going through the thermostat never goes above 185. Find a cheap Infrared temp gun to check it. some thermostat housings have holes tapped to put the temp bulb in.
Jon
