I will also be pulling my engine in the next few weeks on my 62 C10 with 235 and three speed column shift. My plan was to pull the transmission separately from the engine/bellhousing and leave the bellhousing, clutch and flywheel in place on the engine. I am hoping that removing the hood and radiator will give me enough room. Has anyone pulled a 235 with bellhousing attached and left the radiator core support in place?
