| | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | Barnfind is on the money with the Ford lug pattern. You'll need '97 model or earlier wheels from a Ford. The front bumper looks like one for a 1/2 or 3/4 ton truck (and maybe 1 ton). The bigger trucks had a deeper channel bumper.
