| | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | The slack in the pushrod travel is definitely an issue. You need to fabricate a longer rod, but don't use just any old bolt or all-thread rod except for checking purposes. Most master cylinder pushrods are made of hardened steel so they won't bend during a panic stop. I'd recommend using a Grade 8 bolt like a cylinder head bolt, etc., something that will be tough enough to resist bending when the brakes are applied "vigorously". Jerry
